Now the details: So, I still would need PU resistors and at what value?
Also, what value for PD resistors?
Thus, when foot SW closes +5V enter into AND gate allowing A# (or B) to be added to C and when the switch is open the PD resistors earth out the gate and only C gets through.
R values? PD I suppose 10k would be a good one to try. ANd PU maybe 1k? The PUs are on most of the time, but 1K only draws 5ma. I guess the PD could be 1k as well, after all, only one of them will have current at a given time.
Remember that the ROland has the matrixed keys, and we have to connect two things together. You could emulate the Roland circuit in logic, but it would not be a couple simple gates. Wwe would gave to find the pattern and polarity of the Roland strobe, then we could gate that strobe through to the appropriate return when the rmote key is pressed. That woul dbe a little similar to the footswitch method
