So before I start, I'd like to mention that I am a complete n00b when it comes to building tube amps (please don't make fun of me...I had to start somewhere). I've lurked around here for a while trying to learn as much as possible from people a lot more knowledgeable than myself. I just completed my first build (a 5E3 deluxe kit) and I need some help.
Initially I thought the amp sounded great. My living situation doesn't permit me to play loudly very often, so the volume knob was restricted to about 3 or so. Several days ago I took it over to a buddy's house and was finally able to crank it, and immediately something didn't sound quite right. With the volume past about 4 or 5, it starts to break up in a really strange way. I'm not exactly sure how to describe it, but the distortion is extremely fuzzy, and the tone has a strange inflection (for lack of a better term, I suppose) sort of like an "eeeeeooow" sound, if that makes any sense. This effect is more pronounced with more forceful picking, and the tone returns to a more sonically pleasant region as the note decays.
I had hoped that maybe this was just an effect of extreme clipping somewhere in the preamp, but I checked the bias of all the tubes, all of which seem to be operating at reasonable quiescent points (I say reasonable because the schematic I had didn't list any voltages, so I'm not entirely sure what B+, Vk, etc. is supposed to be for any of the tubes). I checked the output of each preamp stage with an oscilloscope, and everything looked relatively clean up until the phase inverter. The waveform at the phase inverter looked extremely similar to that described on this page of Merlin B's site... The Valve Wizard
(look at the section titled "avoiding unpleasant overdrive tones"). He suggested adding a large grid stopper resistor at the grid of the cathodyne, which I did. Unfortunately, while this cleaned up the output of the cathodyne significantly, the strange sounding overdrive persisted.
The only other thing I could really think of to do was move around some heater wires, in the hope that somehow AC ripple was getting into the signal path or something. This didn't work (I don't know...like I said I'm a n00b). Hopefully someone out there has heard an amp with similar problems and can suggest a possible solution, or at least a clue as to where to look.
Thanks in advance for your help. And I apologize for the huge block of text...I realize I'm long-winded.
