Hey guys new to the forum and new to electronics troubleshooting for that matter. I do know how to use a meter however and hope with a little guidance I can repair the said amp. I am supposed to be receiving a schematic from peavey for my model soon.
When I first started it was blowing fuses when switched on. Called PV tech support and he told me to unplug the two transistor bank connectors (with red, white, blue wires) from the power supply board and try another fuse. Didnt blow a fuse this time but smoked a small resistor on the power board. Called him back and he said I might need to unplug the autoformer which could be mimicking a load. I have not yet proceeded with this step.
For some background on the unit, at one time in the past it was discovered that some of the transistors on the back of the unit were bad, which seems to be a common issue, and so replaced with a supposed acceptable part. The first 2 (from left to right on back of unit) SJ6357's were replaced with NTE284's and the third with a ECG284. I have done enough researching and reading of posts to know that I should go back with the OEM parts. All the rest are original to the unit (1979). No direct shorts on any of them but different ohm readings among the originals and understandably among the replacements. Should I be concerned with this?
On SJ6357 transistors 4,5,6 I get a reading around 28-37 Mohms from b-c (I get 0.55 if I reverse leads); 7-9from e-c; 5-6 from b-e. However on transistors 7 and 8 I get an open line from b-c although the rest of the values are in line with the others. Does this affect me or am I spliting hairs? Just for fun I dont get a reading from e-c on either one of the NTE transistors and I only get 5.8 from b-c on the ECG.
So as of right now I need some transistors to at least replace the aftermarkets and a new resistor that I know of. Im gonna have to find out about that resistor. The schematic is going to help with this.
