Hi I have an SR&D (Scholz) Randall RRM2-80 amp that is causing me some grief. It is from the late 80's. When I bought used it worked great. I noticed the ground pin had been removed from the plug so I decided to solder in a replacement cord, hardwired. The amp bgan to have a 60Hz hum. Before it was wisper quiet. I have tested by using aground lift adapter and also by reversing line and neutral. The replacement cable is European, has brown and blue wires, 16awg tough. I was wondering if this wire might be different from NA, other than the colour, but I don't think so. Attached is a schematic if anyone can help? Thanks.
Tim
Tim
