I have a PC2x on the bench that is driving me nuts. It has no audio output, and no signal from the DACs. It passes all the diag digital tests (RAM, ROMS, etc. Keyscan diags show that the keys are recognized, and the MIDISCOPE shows that it is generating the MIDI events. Local mode is on.
Any Kurzweil techs out there that might offer further suggestions?
It originally came in with "Scanner is dead!" errors. After going about as far as I could at the component level, I ordered the main engine board. The new board arrived with different type connectors and I had to devise adapters to mate them up. At startup, the display went straight to "Install engine". Performing a hard reset returned to that point. After much difficulty, I finally got it to load the new engine OS, after which it still would boot to the Install Engine prompt. Diag tests showed ROM checksum fail. I reloaded the boot block, and the ROM checksum now passes, but there is still no audio output.
TIA...
TIA...
