Eden WT405 Warm Trim Poti broken!
  • Eden WT405 Warm Trim Poti broken!
    Hello from Germany,
    the Warm Trim Poti of my Eden WT405 Time Traveler is broken! The smal Plasik-Head that can reached from the Front is lieing on the ground of the Amp. It is very difficult to take out the Preamp-Board to have a look to the Poti because there is less space between the Preamp - Board and the cooling fins. Is there anybody who have had the same problen?
    I need the Chematics to find the right Trim-Poti.
    Thank you very much for your help!
    Matthias
