I hope this is a simple question. I have a damaged KEL HM-2D which I have repaired. When reassembling, which direction should the element be facing? It has the wire screwed into one side, and the other side is of the element is simply bare. Is the screw side the front or back? This is my first time repairing a microphone. A genius friend of mine (**cough** um, actually me).., tried this mic out on a snare drum. It got hit a couple of times, dented the screen and broke the plastic bracket that mounts the element to the body... this caused the wire connected to the center of the element to also get disconnected. When I took it apart, the element was floating around inside the windscreen (not good at all)... so I didn't know which way it had been facing originally.
Any help would be greatly appreciated. I don't want to assemble it the wrong way.
