Today, 10:01 PM
Hi guys. I'm hopeful to get some advice from the electronic sages in these forums.
First, let me tell you my problem.
I have a plan to arrange my car's receiver in my home as well as a mini amplifier, which both you know take 12v dc current from the car battery. I am hoping to find a converter/inverter that will do so and to understand the difference between those two words. Its easy enough to find a 12v DC to 120v AC inverter but I have failed to find any 120v AC to 12v DC converters with the amount of wattage I need produced (about 400 if both the receiver and amp is installed, 300 for amp 100 for recievers amp) I am wondering if these common inverters are backwards compatable, so that I can just use any DC to AC inverter in the home by installing it for use as AC to DC. If not then what is my next option?
thanks.
thanks.
