I have a Roland Cube 60 and I'm making my own footswitch but I'm not sure what parts I need. I had a TubeWorks head in the past so I'm just using the casing from the TubeWorks footswitch. The way I plan to make it is 3 switches, three inputs, three cables. I'm just not sure what kind of switches, inputs or cables to get. The first picture was how the Tubeworks pedal was wired, The second is the same, just closer zoom. When I plug in the stereo cord to the Channel Select footswitch output and attach the wires like in Pic 2 it works but I have to tap the switch twice. If I leave everything the same but plug into the Effects or Delay/Reverb footswitch output it doesn't work. My guess is they're different because one is on/off and the other switches between two channels. Anyway, if I can get any help I really appreciate it. But specifically what I'd like to know is
1) Type of switch? (and only have to tap once to switch)
2) Type of cable?
3) Type of input?
Thank you.
![Click image for larger version
2) Type of cable?
3) Type of input?
Thank you.
