Does anyone out there happen to have a (Regal) Lifco 630-2 amp such that they could help to trace out a few connections on it?
The "Lifco 630" seems to have 4 inputs, but no reverb.
Tube lineup = 4x 6AV6 (3 pre-amp, 1 tremolo), 2x 6BQ5 (output) and a 5Y3 rectifier.
The "Lifco 630 2" (which I have) takes 2 of the general inputs away, but adds a spring reverb circuit with a 12AX7 and 6BM8.
The problem I have is that the previous owner of the amp removed all of the electronics associated with the spring reverb. I’d like to restore it back close to original operation - or at the very least have it operate as the original did.
To that end, does anyone happen to have a 630-2 such that they’d be able to trace out the connections for the 12AX7 and 6BM8? (Based on the photos at http://music-electronics-forum.com/t23663/ it looks like half of the 12AX7 is unused - but there’s no way to tell the interconnection of the 6BM8. It also seems like the 6BM8 is used in the drive cct. and the 12AX7 is in the recovery, but I’m not sure of that).
Failing being able to trace out the actual wiring, does anyone have specific experience with this amp/amp-head such that they can describe how the reverb interface ‘works’? E.g., there is a separate “Reverb Input” jack. Is that the only way to have reverb added in, or will the main channels route through the reverb if there’s nothing specifically connected to the reverb jack? Does the reverb output only get added in post tone-stack or can the 'verb'ed signal also be modified by the tone controls?
