I ordered some components online, and I received them and thought they made a mistake with the wattage of a couple of resistor values.
I found that a couple of values (470 ohm and 100K) metal film resistors had the size of the "older" but still new 1/4 watt resistors instead of the 1W I ordered. They are Phoenix passive components brand, made in Brazil.
Then I checked the the data .pdf and they indeed are rated 1 watt, but they are really tiny. A "normal" metal film 1/2 watter is about 2.5 to 3 times bigger!
I am scared about placing a 1W 100K dropping resistor or plate load resistor in the B+ that is just a little bigger than a 1N4148 diode!
Any experience with these?
