Soundcraft Spirit Folio 12/2 one channel not working
  • Soundcraft Spirit Folio 12/2 one channel not working
    Hi,
    i've been using the above mixing desk for a while now with everything working fine. However, I notice today that only left channel is working. I've swapped leads, checked soundcard and output is fine (it's an external M-audio), speakers on monitor ok as is also a tv.
    Conclusion is that some kind of fuse has blown, I think.
    Anyone any ideas what part of the desk needs to be looked at, which fuses are responsible and need to be replaced? Is this something I can do myself (novice and technophobe, but have replaced fuses in technics 1210 record deck on several occasions) ?
    Any very basic suggestions or specific fuse replacement advice much appreciated.
    Thanks in advance
    Ox
    Well it's not going to be a fuse (at least not in the mixer unless it has a built-in power amp section).
    If there are "Insert" jacks for the main outputs try plugging something in/out of them a few times to exercise & wipe the normalling contacts in those jacks. Also if there is a "Main/Mon" switch for the outputs try pushing that in/out a few times for the same reason.
    Sometimes it is the jacks or controls that never get used which can build up oxidation & cause problems.
