I need to replace the Thermalsil pad that backed a barbecued TDA7294 amplifier chip in an Anchor powered speaker.
http://www.st.com/internet/com/TECHN...CD00000017.pdf
The amp's nominal package size is .772"W x .689"H (19.6mm x 17.5mm)
Aavid does not sell this configuration as a standard size pad.
I assume Anchor cut their own pads from bulk Thermalsil rolls.
Mouser does not normally stock Thermasil rolls, but will sell PN 5300 1.500G (1.5"x328') for $4.28 - with a minimum order of qty 245.
I am not looking to organize a group buy - just need a small piece of something that will work, fast.
I see that Aavid's mica insulators are 1-3mil thick. https://www.aavidthermalloy.com/prod...nsulators/mica
I've found (3) 8"x12" sheets of 1mil Kapton on eBay for $5.99. Any reason that won't work (with heatsink compound)?
I've also got some of this 3mil sheet Teflon on hand: MusicMedic.com: Sheet Teflon®
CAN THIS BE USED INSTEAD OF MICA OR KAPTON (WITHOUT BURNING UP THE NEW AMP)?
ANY OTHER SUGGESTIONS?
Thanks,
-rb
Thanks,
-rb
