Looking for advice, if you please.
    The best amps had sliding wire wound resistors to adjust for the tube and the line voltage variation.
    You wanna adjust it to produce equal clipping plus and minus with a clean input, at least adjust it "that" much...
    but I would rather adjust the cap value too.
      Guitar amps are just a clever way to operate tubes poorly.
      Fixed that for you!
      On my amp I found that I could turn the screen voltage down nearly to zero, and the clipping (from the overdriven power tube) was still reasonably symmetrical. That says to me that the cathode bias self-adjusts reasonably well.
      The required value of cathode bias resistor probably varies as the one-half power of the line voltage, or some other ridiculous piece of math.
        Hmmmm... I was going to say "thank you" but that button seems to be missing. So you get a "like" instead. Because I agree. And it's good to know the cathode bias is so forgiving for this application.
          Still, if cathode bias was truely self adjusting such that you could scale the voltages down quite low without bias consequences then why do we bother to choose a particular value resistor for a particular amp? One resistor value could be used for all amps in all instances!?!
          Please do not mix different things.
          1) *different* tubes in *different* amps require *different* cathode bias resistor values, optimizing bias current according to particular needs.
          2) once you settle for a given value in a particular amp design, turning +B voltage down is accompanied by a *reasonable* bias self-adjustment.
            being in over your head forces one to attempt to swim
            tonequester here.
            soundguruman. I have to admit that I've become out of my league, as this discussion has progressed. I am learning alot. However, I am slow to bone up
            on as much info as has been presented here so far, especially when there are some varied opinions. I have come to only one conclusion which I believe to be an absolute,
            that being ...if there IS a science of tone. It is more a matter of opinion, than a matter of science. That being said, your recent comments make sense to me. I was impressed
            by your thought about adjusting for equal + and - parts of the clipped signal. I believe that Chuck H made a good point on the probable limitations of cathode bias(everything
            has it's limitations outside of God). I thank you both for your input and providing ideas for me to check out further. Steve Conner. I find your results concerning reasonable clipping symmetry while using close to zero screen voltage to be welcome news to me, as I am considering going that "route". I wonder if it is a given, if one would see the same symmetry with a similar increase in screen voltage of the same proportion ? Just curious. I love your comment on "rediculous mathematics", mostly because my own math skills are rediculous "in the negative". Thanks so much for the reply. JM, I appreciate your pointing out that "different tubes in different amps", and the mixing of tubes in an amp has serious consequences that have to be addressed properly. I will resist any temptation to do so. I detest smoke and fire, especially when it comes from any of my equipment. This has been a great discussion, and I have picked up on some good info with quite a bit more to further investigate. Lest I forget, thanks also to Gibsonman63 for the lead on VVR by way of hall Electronics. Happy to make your "aquaintance", and I WILL check it out. I would like to think that the 5 star rating somebody has applied to this discussion means that the content is A+. I'm pretty sure that this is the case. However, a part of me is thinking that alot of people are having a riot at the
            stupidity of yours truly. As usual, you guys are great. Thanks for your time and participation. tonequester.
            Quote : "Hell, there are no rules here....we're trying to accomplish something here ! Thomas Edison.
