Hi All.
The Behringer B300 powered speakers use 3x parallel conected Lm3886's for the woofer, and 1x Lm3886 to drive the tweeter.
The outputs of the three driving the woofer are linked via 0,1Ohm resistors.
My question is this: Should those lm3886's be matched, or have the same batch numbers?
This would be a PITA as I have a couple half dozen of these, all with diff batch numbers.
I have replaced all of them in one unit. Haven't put a signal through it yet, but there is little/no offset voltage present- a good sign thusfar.
