Invisible vibration dampener?
  • Invisible vibration dampener?
    Here's a somewhat silly question with only passing electronic content:
    I just picked up a Dano HoneyTone mini-amp for real cheap.
    At moderate volume, the top of the "HoneyTone" emblem vibrates against the body.
    What would be a quick, easy, non-ugly way of damping the vibration?
    I don't want to just cut the emblem off the speaker grill, cause I think it looks kewel.
    My first thought was paraffin wax... which would be a mess.
    Maybe white glue? There must be a more elegant solution....
    Thanks,
    -rb
    DON'T FEED THE TROLLS!
    Slip a piece of sponge shim under the emblem plate... you know, take some sponge and slice off a sliver of it to use as a shim, tuck it under the emblem with a putty knife or something like that. If it don't work you can just push it back out... no foul no harm.
    ... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
    marsbahis betturkey
