Thank you all in advance for my newbiness. So i am very new to electronics fiddlin, very new. I am however an electrician by trade so i have potential i think. I am a recording engineer and musician to give you a little bit about myself.
Anyway i got this old drum machine, very old and rare apparently. When i turn it on and plug it in, i get this crazy loud screeching sound. Real loud. I plugged it into a guitar amp and have it down as low as it will go. I opened the unit up and found these "components" that you can adjust with a screwdriver. I think each drum hit section has it's own one. Volume control maybe? Anyway when i turn them they make some pretty cool strange noises. And if i turn some of them down the noises go away. But nothing on the drum machine works. No beats. Not even distorted messed up beats.
Do any of you kind people have any idea what this noise is? And is it hard to repair or expensive to have a tech fix it? It's probably from the 60's early 70's. The circuitry doesn't look very complex.
THANK YOU!!!
THANK YOU!!!
