How to change an INSERT to an AUX on Yamaha MG124c
  • How to change an INSERT to an AUX on Yamaha MG124c
    Hi there,
    I've bought a Yamaha MG124c and thouhgt that I could use the INSERT's to split the signal that it will go to my PC with M1010LT and parallel to the MG124c for Mixing by a simple bridge between the hot and cold part of the jack. The reason is, that I like to record every channel seperatly and mix it for "studio" purpose.
    The problem is either the delay (latence) if I return the signal by the M1010 or the compression of the signal (in case of the bridge) so it will be too worse for recording.
    Do you know a circuit drawing for a "pre amplifier". I think phase invertation will be necessary, but I am not a electronic designer.
    Any tip is welcome.
    Kind Regards
    Hans
