Head pad felt matierial for Reel to reel
  • Head pad felt matierial for Reel to reel
    Interesting that the last thread was about a reel to reel, too.
    Anyway, does anyone know of a source for 'real' felt that can be used for head pressure pads? In this case it could be between 3/16" and 1/8" thick. I've found all kinds of synthetic materials that are too abrasive or might catch on a splice at the typical sewing-hobby type joints.
    A million years ago we used to be able to get a square of this stuff from hobby shops & just cut up your own head pads or even purchase them pre-cut with adhesive backing for this specific purpose, but alas...not much call for that these days.
    I see online where the head pads for cassettes are available with adhesive backing, but of course that's for 1/8" tape & wouldn't work here.
    Any ideas would be greatly appreciated...glen
    Moleskin? Just a thought. It has adhesive backing and is readily available at drugstores. Not sure if the material is perfect for the application but worth checking out.
    Edit: The kind for blisters
      Piano felts?
      Got any old reel table clutch felts?
      Go to a fabric store and ask them?
      Are we talking like Echoplex pads? And would one of those work for you?
        Thanx for the ideas.
        Yeah, the fabric stores & hobby stores only have the synthetic stuff which is too abrasive or just too thin. I actually have the felt spacers for the Wurlitzer key height adjustments...hadn't thought of that. The Moleskin might work, too.
        the issue might be the felt washers might not be wide enough...but that opens some other sources. Enzo, what felts for the ecoplexes are you referring too & do you know of a source...thanx, glen
          I wasn't thinking of the individual key shim felts really, I was thinking the strips of thick felt that run the length of keybeds to act as a downstop cushion. But any port in a storm. I used to have to replace glued in felts under some keybeds that the keys eventually cut through. I want to think PC88s, but I might be confused.
          Well hell, I am stupid. COntact a piano repair guy, or piano store, ANy place that does maintenance/rebuild/service to pianos.
          File:Maestro Echoplex EP-2.jpg - Wikipedia, the free encyclopedia
          From the wiki article, look at the photo. From the left end of the tape cart, coming out from under, see the phosphor-bronze springy strip angling out to the upper left, bent around the lid post, and with a felt pad at its end to keep the tape tight against the lower side of the roller. New spring strips with felt came with new tape carts. I don't know who might sell them nowdays. But at least that is what I was thinking of.
          googling "piano felt" first thing up was this:
          Piano Action Cloth & Felt Products
          second thing:
          Piano felt, cloth and leather action parts for all makes of pianos. Technician's tools.
          Wool felt, not synthetic.
          How about google wool felt: ooh, too many to mention
          Don't know, but google "felt pads" and see various responses.
            Hey Enzo,
            thanx for the suggestion of the Wurlitzer & acoustic pianos as a possible source for the felt. I realized that I still had some key felt bumper strips in my Roland stuff. The strip of bumper felt was just over 1/4" wide & just the right thickness a well as with adhesive backing...couldn't have been a better fit.
            g
              edited
                Enzo is the one with bright ideas. Thank Enzo replying Mars Amp Repair.
