BEHRINGER DDX3216 Files Button PB
  • BEHRINGER DDX3216 Files Button PB
    Hello,
    I recently bought a second-hand DDX3216 who's work fine except one amazing problem:
    There is some buttons like FILES,MMC/MIDI who's don't works.... no action when push it! led include on the button not lite on.
    All over function working good but i can't enter for example, in file menu, to configure RS232 (OR midi menu for the MMC/MIDI button)
    I read the big and interresting Thread about this console on this wonderfull site, and i found schematic. This help me to more investigate my problem:
    The switchs are the CTRL03 board and are named S27 and S28. They're working very well (0 ohms when pushed). On IC7 (74HCT165) pins 5 or 6, i can see 5V when button is Off and 0V when pushing the button => so it's seem to be right.
    I can see that others switch who's wired to the same IC are working well. So i assume that after the switch action is serialized on DS1 line by the 74HC165, all electronics behind (who use this line) work fine? So if i precise: not all off the 8 switch serialized by this IC are hs, so i think that the problem is not in the use of the serialized signal DS1. For example S32 (SETUP recording automation) work normaly when i push it.
    To be complete, there is no change on LCD screen when i push these 5 buttons : FILES, MMC/MIDI,RECORD,PLAY,RELATIVE
    Other than all the rest works fine!!
    I don't think that there is only 5 inputs of the 8 on IC7 who's die? I ever see a IC who's working partially...
    I'm successfully realise a factory reset and a firmware update (via midi because i cannot configure serial ... off course), but the pb is the same.
    These buttons are not very important in a normal use of the console... but i want to understand... If you have any ideas?
    Thank's a lot!
    First thing I would do is resolder IC 7
    Do all the buttons related to IC 7 Exhibit the nogo result ?
      Originally posted by S2udio View Post
      First thing I would do is resolder IC 7 => Already done with no effect
      => There are S25,S26 and S32 who's work normally on IC7, the other 5 switchs, have no effect when I press it.
      I don't understand why there is only 5 switchs who's don't work on the 8 input's of IC7... this isn't logic!!!
      In any case, thank you for taking time to help me....
