I have an alto megavox pb-35w battery powered portable pa that's giving me fits.
The problem seems simple but I can't find the solution.
Basically it won't power on. there is a relay that sends power to everything when the coil is activated by a switch (switching 12 volts)
I can't get voltage accross the contacts of the coil. I can hear the relay switching & when I take the relay out & power the coil i get continuity across the contacts.
When the relay is in the circuit & powered up the 12 volts doesn't make it across the contacts unless i jumper 12 volts to the side of the contact needing it. Then i can remove the jumper and it works fine. I have tried replacing the relay with a new one and that didn't work.
Any ideas would be appreciated!!
Thanks!!!!
Scott
Thanks!!!!
Scott
