I am putting out a request for some help on a modded Univox U-1061 bass amplifier.
When received the amp had a blown output transformer (original OT )
The 6550 big bottle tubes test good.
The diode array on one side was shorted.
The ot is bad.
I believe the amp was operated on the 8 ohm tap with a four ohm load.
Now onto the question:
This output section on this amp has been modded.
1: 100 ohm/ 2 watt plate sharing resistors: removed
2: 1.5K screen sharing resistors: removed
Items added:
1: four 50K grid resistors
2: four 47 ohm/ 5 watt screen resistors
3: a triple string of diodes (plate to ground)(251D 1000v/ 2.5)
4: .001/ 2000v cap across diode string
My question is : are these good mods?
Why did the OT blow?
Why is the diode string shorted?
What the he## is the .001 cap for?
I have attached the original & modded schematics.
The ot is bad.
Items added:
