HelpPlease;UnevenStringsSoundAcousticPluggedIn
  • HelpPlease;UnevenStringsSoundAcousticPluggedIn
    I have a plain Yamaha Acoustic (not Acoustic/Electric) have only played acoustic tryin to plug in for more volume, I know very little about the electronics side of music gear.I Got a Roland MicroCube practice amp, and a Dean Markley Pro-Mag Plus pickup that you just place into the hole and plug into the amp. works good exept theres a constant fuzzy sound coming through the amp even when the distortion is low and holding the strings mute.
    But the thing I realy want to solve is that the High e and B strings ring way louder than the rest G,D,A,E. With no volume/tone control knobs for the guitar I don't know how to level them out.
    Ant suggestions??...
    Maybe a lighter gauge of strings for just those 2, or heavier strings for the other 4? Just Have Standard strings on all of em now.
    I Appreciate any help, I need to learn more about the electric stuff.
    It appears that the pickup is not quite correct.
    I would suggest contacting there customer service department.
    There is no way to 'even out' the string loudness, even with an EQ.
    It is a single coil pickup, so you will get that single coil buzz.
    Not too sure about the noise that you described.
    Contact Info:
    Dean Markley Strings, Inc.
    3350 Scott Blvd., #45,
    Santa Clara, California 95054
    USA
    Toll Free: 1-800-800-1008
    phone: 1-408-988-2456
      Try steel strings instead of phosphor bronze.
        +1 ^^^
        the unwound strings are plain steel while the wound are likely a core wrapped with a less inductive alloy. I have routinely put electric guitar strings on acoustic guitars for that reason. Mind your gauges
