Peavey XXX strange problems
  • Peavey XXX strange problems
    I have a Peavey XXX 100 watt head in for repair. What is happening is the crunch chan. controls the ultra chan. unless first engauging the clean chan. first. All leds work properly and relay K3 is firing and switching properly (measured continuity). Any ideas ???
    Many thanks
    John
    Sorry relay K3 does not change states with out going to clean chan. first
      Post the schematic?
        Here is the schematic
          Thanks for the schematic.
          I am not at all clear on what you are seeing.
          If the Crunch & Ultra LED's are functioning then the circuit is good (Q7 & Q11)
          If K3 has +17Vdc & the Ultra LED lights & K3 does not engage, that would indicate a faulty K3.
          Is there any change in the symptoms between using the footswitch or the front panel pushbutton switch?
            Ok here is what I found.
            In Ultra mode
            1.8 volts across K3
            10.0 volts across K2
            In Crunch mode
            10.0 volts across K3
            0.0 volts across k2
            meaning logic circuits working correctly.
            But Crunch EQ's still controlling the Ultra circuit.
            K3 Relay contacts will not change states to Ultra unless clean chan. is enguaged first.
            Started to suspect "lazy" relay.... replaced K3 and all working good now
            Thanks for the advice
            John
