Hi guys, I am new at the forum. I have been sneaking around, reading and getting great info from here for some time. Funny how you make a Google search about anything "amp repair" related, and most of the results are threads of this great forum.
I registered and contacted Enzo asking for help. He kindly instruct me to post a thread. This is a copy of the message.
I am looking for some input regarding a Marshall DSL 100.
I got this head from a friend, because it isnt working properly. It has low output. The head sounds great, all controlls work fine, no hum, no noises , nothing, sound really good, only with the volume on 6 you get "loud bedroom level" , I mean is loud but I can't see this competing with a drummer in a rehearsal situation.
I have a few other Marshalls and just retubed a TSL for a friend, which is really loud by comparison. So I know there is something going on.
The DSL was repaired a couple of years ago by the only authorized dealer here in Puerto Rico. It got the pcb of the power amp replaced, because of the runaway bias issue. So the board is new. Tubes are new, and testing OK. I suspected the OT, but I got another one to try it with the amp, and it sounds the same.
I have read about this happening to other people "after " the power amp PCB replacement. In fact I was reading in another forum, some guy had this same exact issue, with a DSL100 "after" replacing the power amp board> Funny thing is the guy said he was in Puerto Rico, So for a while I was thinking I got the same head, in fact I am not sure if it isn't.
I know it is almost impossible to give me a 100% answer without actually looking at the head but any help or info will be apreciated/ Today I replaced all the preamps tubes, but nothing. Also the jacks on the FX loop are in perfect order, and just in case I plugged a patch cable to test , but nothing.
I plug the guitar in the Loop's return to check but nothing, same output. I replaced the PI tube a couple of times and nothing.
I was looking at the controls board and I think one of the realys might have been replaced (the black one on the pics) as the other two are white. Althought all channels have this issue, the lead and ultra have a bit less output than the clean and crunch.
Last thing, I see on the replaced power amp board, conectors 15 , 16 and 12 are not used, they have nothing conected to them. Same with the terminal W8.
I talked to Marshall customer service and they told me conectors 16 and 12 are not used. They didn't say about the con 15 and W8.
The board is JCM2-60-00 ISS 20. (Just in case).
Again any help, will be appreciated.
