Behringer B215XL PA speaker help
  • Behringer B215XL PA speaker help
    Hi, Guys.
    I have in for repair a Behringer B215XL 250w rms PA speaker with a faulty 15" bass unit.
    It is one of those moulded plastic cabinets which can be split apart by removing the back screws,but the speaker is obviously been screwed in from the front.Has anyone any idea how to remove the metal speaker grill without damage,to gain access to the screws behind,or is this another throw away job.
    Cheers, Peter.
    If you can see the mount screws through the grille, then indeed it is front mount. You use something pointed or a small screwdriver to pry the grille out of its groove. But look close for some small screws on the grille. I have serviced these but don;t specifically recall.
