soldering onto conductive paint or glue
  • soldering onto conductive paint or glue
    Hi All
    I have a Roland 80017A chip that has lost one of its legas and solder pad that the leg solbers onto
    Can i use a conductive paint (suspended aluminium particles, Bare Paint or any other kind of paste/solution to cure this
    Cheers all
    V
    Given the pad size it may be better to hard wire the IC leg back to the nearest good solder point. This is likely to be more successful than using conductive paint. I'm assuming that there's still a stub of component leg left.
      Yup, what MB said.
      A very fine strand of copper wire will also assist.
        This is what the 80017A looks like under the epoxy.
        http://music-electronics-forum.com/a...1&d=1367190131
        If the solder pad is missing you might try conductive epoxy. Use a thin strand of wire as suggested.
        CW2460 ITW Chemtronics | CW2460-ND | DigiKey
        I can't believe that price. Last time I bought some it was about $25
        Doug
          Doug
          Hey!! Why do you complain!!!
          They *do* offer ways to buy it for substantially less !!!
          All prices in Canadian Dollars:
          Price Break Unit Price Extended Price
          1 188.55000 188.55
          25 169.69480 4,242.37
          100 136.69860 13,669.86
          500 122.55740 61,278.70
          BIG savings !!!
            BIG savings !!!
            By golly you're right!!! If I buy 500 I would save $33.000. I could use $33,000... Yeah!!
