Mackie Th12a no bass sound
  • Mackie Th12a no bass sound
    Hi sorry for my bad english but i'm italian.
    I have replace the tda8950th in my th12a and the sound of the bass is nothing.
    What is the problem please help me.
    -Possibilities:
    -the speaker is bad.
    -the power supply voltages are not good.
    -the new TDA8950 is not seated properly.
    -the PMW signal is not present.
      thank you for reply
      I did some testing
      i have a second mackie and from the tests I've seen
      - the speaker is good
      -the power supply is good because if i mount the amp board of the second mackie the sound is present
      -the tda8950 is seated properly
      my ask is:
      how do i check if the pmw signal is present?
      in the tda8950 i have 50v on the out...
        Can you post a schematic?
        There ia a Mode pin that could hang up the output.
        Standby the pin is at 0 volts, Mute: 2.5 v & Operate is 4.2 volts.(DC)
        Also a Protect pin.
        The PMW is internal to the IC.
        I do not see how 50 volts can be on the output.
        You do understand that this is a Class D device?
        Here is the IC datsheet:
          i have check the mode pin and i have 5,45 volts but on the stab pin (18) i have 5,5 volts and not 9,8-10v!!!
          if I measure the output pin I have 50 volts and not as 150mV datasheet
            this is a schematic of the amp board:
            TH-12A AMP SCHEMATIC 0021633-XX-E09-SCH.pdf
            and yes i have understand that this is a Class D device but if i measure the pin out i have 50 volts DC
              Are you making the measurement After the low pass filter.
              If not, then you are measuring the carrier wave.
                my measure is on the connector pin, if i measure on the amp board good the value is 30mV-120mV change in according with the volume, on the amp board broken my value is 45-50V.
                On the broken amp the value on the STAB pin is not regular, i see the data sheet and the value is 9,8-10V in my amp board the value is 5,45V.
                i have measured the voltage on the pin STAB and VPPS.
                I don't understand the problem...
                P.S: if it can be useful a friend of mine before I replace the TDA8950 had mounted on the board without the pad, so I think he has short-circuited something
                thank you for reply Jazz P Bass
                  On the working amp, what is the voltage on STAB & VPPS?
                  The STAB pin is merely a decoupling pin, hense the capacitor, for the Internal power supply of the IC.
                  And check the MODE pin .
                  It should ramp up at turn on.
                  That 5.45 at STAB sounds as if the IC is in the Mute condition. (for whatever reason)
                    on the working amp the STAB pin voltage is 9,8-10 Volts.
                    I have check the mode pin and the voltage is 5,45 V (is regular and operate)
                      Alright, how about the protect pin?
                      If that is o/k, then I can only assume that the ic, for whatever reason, is bad.
                        ok but the ic is new what is possible?
                          I don't know.
                          This is a 'stand alone' IC.
                          Give it power, a signal, make sure the protect & mute pins are good & away it goes.
                            perhaps the problem is on input i don't check the input pin
                            on the datasheet the voltage on IN1M,IN2P,IN2P and IN2M referenced to SND have value -5 +5 Volts now check this voltage...
