dynacord powermate mk-1
  • dynacord powermate mk-1
    hi lads i have a powermate mk-1 im running 2 400 tops off the desk nicely however i want to add bins to the system and was thinking of getting and extra power amp to drive the bins is it possible for me to run the bins from the power amp and tops from the powered desk thanks
    Yes - keep the tops as they are and the Dynacord PM1000 manual shows how to connect the external amp off the EQ outputs on page 26 "connection of an external power amplifier".
    Note that there's no active crossover function in doing this and you'll be reliant on your bass bin cutoff or its speaker response limit.
    You also need to make sure speaker phasing is correct off your power amp.
