Hi there,
This is my first post here so I hope this is the right place to ask.
I bought an inexpensive analog transistor based organ. It's a Gracia (Armon) Charlie 37. It was in bad shape; noisy pots, lots of dust, paint + sharpie markings + stickers on the keys. I totally cleaned it up and it looks like this now:
100_1271_zpse8e8bffc.jpg Photo by AJDbass | Photobucket
It has a build in speaker. I wanted an line out to amplify the organ so I could use it for rehearsels with the band. There was a jack input for a pedal wich was missing, so I pulled out this jack and replaced it for a line out-jack. I found the pcb which contains the power supply and the power amp. I bypassed the white wire which goes to the input of the power amp. The white wire now goes from the output jack to the power amp. If a cable is inserted the signal to the input of the amp is broken.
100_1277_zpsf708911c.jpg Photo by AJDbass | Photobucket
The level of the line out is perfect for a guitar amp and I can control it with te volume control on the organ. The problem is that when there's a cable in the output and there is no signal to the poweramp of the organ, the internal speaker gives a loud hum.
I don't really know how to eliminate this hum. I don't have a schematic. I was hoping someone could give me some tips... I am kind of stuck. Thanks.
