I asked this over at DIYSB, but I'd like to see what you guys say over here too:
For my internal bass preamp, I would like to use a small rechargeable battery, like the one in a phone or something of the sort. The problem is that those tend to be 3V7, 9V is standard for most guitar circuits. So I'd need to raise the voltage. Perhaps higher than 9V, since it's being stepped up anyways.
Now, there are many ways to do this. I could probably fit a switchmode supply in there. Or there are those voltage multiplier ICs. But, being weird, I'd like to use a linear supply. If I use an oscillator to generate a sine wave, couldn't I just treat that as similar to the mains? A transformer could step up the voltage followed by rectification and filtering, or I could use some of those diode voltage multipliers. I think it would also double as a safer way to practice mains wiring, since there is less voltage and current there.
What do you think? I suppose it's crazy, but it's still doable, isn't it?
