So what is 'differential feedback'?
If you have found the answer, that is.
A fully differential amplifier, usually referred to as an 'FDA' for brevity, is a DC-coupled high-gain electronic voltage amplifier with differential inputs and differential outputs. In its ordinary usage, the output of the FDA is controlled by two feedback paths which, because of the amplifier's high gain, almost completely determines the output voltage for any given input.
I think it simply means the amp is balanced throughout with two feedback paths. Then again it could mean almost anything, as audio companies love to stick random buzzwords on their products.
It usually means there are two two feedback paths with different bandpasses. One for audio and the other with a bandwidth(lowpass filter) of less than the lowest freq. of
audio passband. That is required for Dc balance in a direct coupled circuit. Any way, that is what it has regardles of their terms.
