Traynor YBA-1A Mark II paper fusing label
  • Traynor YBA-1A Mark II paper fusing label
    My 1973 amp has what's left of a small paper label inside, pasted to the chassis right by the fuse holder. A previous owner has scratched most of it away - anyone got a picture of one?
    Looks like it would have read something like "Replace fuse with correct type and rating".
    I believe an amp from that year would have originally had a circuit breaker.
      That's the label! I can see from the fragments of my original that it matches.
      Now, here's a thing; my rear panel is printed up for a fuse "3A slow blow - disconnect supply cord before replacing fuse" and the chassis cutout matches the fuseholder too. Also, my amp has the two diodes across the OT primary and I thought these were deleted before 1973.
      My amp is a factory 240v version, so I wonder if they fitted those with fuses instead of breakers. But why leave the breaker label in for US/Canada? Unless the label was scratched off by the factory when they fitted out the amps for export.
        The Traynor amps I am familiar with were made for the US/Canadian market. They all had an "Accessory Plug" (convience outlet) on the back and a Ground switch (death cap). An amp made for a foreign market shouldn't have these things. Are there holes in the chassis and/or back panel for them? The 73 YBA-1A that I snapped the pic of says "Circuit Breaker Press to Reset" and below says "Disconnect Supply Cord Before Opening". Near the serial number there is a CSA logo and it says "115V 60Hz 2A LR21877". Other older amps that were originally equipped with fuses say "Fuse 5 Amp" over the fuse and "Disconnect Supply Cord before replacing fuse" under the fuse.
        I don't know why your amp has the sticker. Amps were probably made in batches and a batch for export might not have been that common. It might have simply been a mistake made by someone that didn't know any better.
          Mine still had the original death cap, which is unusual for 240v. Most other amps still have the switch but nothing wired to it. No cutout for the accessory plug.
