As you might know, I am a whistler-musician, using Toshiba Satellite L850 laptop and Create Sound Blaster X-Fi Go! USB sound card for recording music together with my whistling. The setup is almost perfect, except that the Mic captures much of my breathing noises.
I paralleled two good electret Mics, which just connect to the sound card w/o a Pre-amp. If I channel the Mic's output via two electrolytics (in reverse), it sacrifices its volume.
Albeit I hate the idea of adding noise via a Preamp, I suppose there's no other solution. I will have to do it in order to increase the Mic's volume and then just filter its output via a right sized capacitor. - So much to my hobby electronic knowledge.
I trust, you electronics experts know far better to solve this problem and I thank you in advance for your good advice.
Watch me "blowing up" here: "Try whistling this slow, easy tune..."
- YouTube
