hello,
I have been trying to wire in a three way lever switch, I have wired the pickups into the volume pots like in this schematic http://www.axesrus.com/images/gibwiring.jpg
I have then wired in the switch using this method https://www.google.com/search?q=les+...ml%3B650%3B550
The problems I am having are:
1. when the switch is in the center there is no sound
2. when the switch is in the bridge position the tone pot is not working properly
I have been unable to find a wiring diagram that uses two humbuckers 4 pots and a lever switch, is this because it is not possible to wire it?
cheers
cheers
