Hi Folks,
I have an ADR Compex which has developed a fault on channel 1. The gain reduction meter needle is deflecting when the unit is idle.
I've cleaned the input/output pots & all the card edges for that channel with deoxit. No improvement.
The fault follows card A of the 3 cards on the channel. I did a swap between channel 1 and 2 and the fault went with it. The deflection also increases with the ratio control being turned up.
(pdf of schematic and flow chart is attached)
There is +24v between the -ve & +ve rails to the card at A4 & A8.
Can anyone please help me get any further with this? I've checked for volts all over the circuit, but am not really sure how to narrow things down.
Thanks for looking
Thanks for looking
