Hi there,
I'm a complete idiot and I dropped out of my electronics class in tech school. With that being said, I decided I wanted to install an optical theremin in a 1980's Lawsuit, Japanese Les Paul copy. The holes have been drilled. The hardware and 9 volt battery fits perfectly inside the volume/tone knob cavity. Ideally, I wanted to be able to solder the output wires on the theremin directly to the 1/4 in. output jack. I ASSUMED that this would allow me to play guitar and use the toggle switch for the theremin to switch back and forth easily. I was hoping this would work because I obviously didn't want to drill a second 1/4 in hole and install a second jack just for the theremin. After soldering everything, I plugged in and discovered my guitar wasn't coming through, although the theremin was working fine. So, I removed the theremin and the guitar went back to normal.
This is simple electronics knowledge that I should understand, but I sadly don't. Is there any way to avoid installing a second jack for the theremin and run it through the original guitar jack? I'm hoping there is. Thanks in advance for any advice.
