Minidisc recording- help pls.
  • Minidisc recording- help pls.
    sorry wrong place for my Q!
    happy new year tho.
    As far as I can tell, you need a BNC to mini cable.
    The Sony will automatically detect a digital or analog signal.
    Something like this: TecNec TecNec BNC To 3.5mm Mini Phone Plug Genlock Cable Assemblies BNC to Mini Genlock Cables at Markertek.com
      Hi JP, thanks for those.
      Now wouldnt I need tho a stereo 3.5mm jack end? which leaves me to wonder how, if a BNC is simply a single pin/ outer shield, it can carry any stereo digital signal at all.. unless the 'coaxial' term means its a dual-function/ '2-sided' BNC socket.. which would mean a different cable needed?
        Sorry, but the "sony' file did not upload.
        What it said was that the input jack can 'tell' if the input is a digital or an analog input.
        If you plug in a 3.5mm 'stereo' (TRS) cord & that cord is connected on the other end to an analog 'stereo' source, the Sony will be perfectly happy with that.
        On the other hand, if you plug in a 3.5mm 'mono' cable, with the other end being a BNC 'mono' digital source, the Sony will also be happy.
        The 'stereo' part of the digital signal is in the digital data.
          I think I missed that about coaxial cable.
          A Coaxial cable only has 2 conductors.
Name:	Coaxial Cable.jpg
            Aha.. understood. I never knew/ that's interesting.. and complicated, thinking further ie how etc. Trific help JP thanks.
              Hi JP. Im still on this..
              So a Coaxial has 2 conductors, which is what exactly as I only see a normal (dont I?) one pin and one shield in the pic there. Are there 2 pins in middle? or aone signal down the copper middle and one signal down the braided bit?
              So then I need a coaxial cable, with a stereo 3.5mm mini jack? but a bnc plug is inherrantly a single pin as said.. so I dont understand how a coaxial cable can be used with it w'out it becoming a 'singleaxial'.
                Think about what you said.
                Now think about the coaxial cable going to your TV set. (Cable, Dish)
                All of the 'information' is in the center copper wire.
                A coaxial cable is 2 conductors.
                The middle copper & the outer shield.
                Just like a guitar cable.
                You do NOT want a 3.5mm 'stereo' plug.
                That will confuse the Sony.
                BNC to 3.5mm mono cable is all that is required.
                Remember that the signal is 'digital'.
                All of the information is coded & sent down the center copper wire.
                  Understood now JP. Actually I just went in to a local 'leccy/tecchy shop & the spotty tecchy-herbert seemed to think I needed a DAC in between the digital out & MD player. Ah crap.
                  Ok another Q: if I did get a recording off my expensive CDP > MD player.. would it be exactly the same quality as if I were to just bung the same cd into my laptop here and go (stereo ends I assume) minijack > minijack from the headphone socket?
                  ie 1's and 0's info is the same right? & its just the playing of cdp parts that make -all- the difference between cdp A and cdp B.
                    You do not need a DAC .
                    Buy the BNC to 3.5mm mono & you will be good to go.
                    Can't answer the other question.
                      Ive just rcvd email back from Roksan the cdp maker..
                      "The Digital output is not meant for recording, but to connect to a DAC for high quality playback."
                      Ok where the heck am I now?! forget that? & still just go with a simple mono phono > minijack (& whack a phono/bnc converter on? only way I see of doing/ fine with me).
                        Could you repost the original question and the make/model of the 2 items? The original post is gone.
                        If the Sony can accept digital or anolog input as JazzP stated, then you do not need a DAC.
                        If Roksan said it can run into a DAC, then it can also run into a digital recording input. They probably thought you meant into an anolog input.
                        I would prefer not to run digital signals through cable adapters. Best would be a pre-made mini to BNC like the link Jazz posted.
                          Hi g-one, by all means: something like..
                          "Got me a Roksan cdp with a 'coaxial digital output' BNC socket on back. Can I use this odd thingy to record from, into a small Sony portable minidisc player (MZ-510). It has the std Line-in and Mic-in inputs, I usually go TT > amp's tape > minidisc but modded the preamp/ removed the tape section wiring you see.. or I could used this for the cdp too."
                          thanks- SC.
                            Should work with BNC to mono-mini cable. No DAC required.
                              O/k.
                              In respect to the replies by people more knowledgeable, I went back & looked at the Sony MZ-N510 inputs.
                              The 3.5mm jack is for Analog signals.
                              It then is routed through a A/D converter.
                              There is also an Optical Jack.
                              This is for the digital signals.The BNC socket is not optical.
                              So, yes, you need a DAC.
