I have a Silverface twin here (Master Volume) that is giving me some trouble. The reverb at first refused to change level. It worked, but just couldnt turn it off , or UP. Or down, for that matter.
I resoldered the lugs on the reverb pot and now the reverb SQUEALS when turned up. I can also hear this oscillation a little when turning up the tremolo. Yesterday i turned the reverb up , SQUEAL , and noticed smoke from the screen resistor on power tube 2....or maybe the grid stopper resistor underneath. It is hard to say. I plan to replace all the screen resistors even though they measure OK.
So far, i have measured the input and output on the tank, measured the primary and secondary resistance on the reverb transformer, tested for output on the reverb send with an 8 ohm speaker (which sounds fine), swapped out the reverb send and recovery tubes. Tested the reverb cables. The voltages on all tubes, both preamp and power amp, measure good.
With the reverb down , the amp passes signal and sounds ok. With the reverb up it squeals. There is also a persistent low level hum which developed AFTER the first time i heard this squeal. I know i should probably recommend to the owner replacing the caps as regular maintenence but im not sure the filter caps are the problem...and not sure he wants to put the money in. The amp was dead quiet before i retouched the solder joints on the reverb pot.
To me the fact that the squeal caused smoke from a screen resistor should be a big clue..But what does it all mean? Seriously , I would appreciate any help or insights here . I did a search through this forum in which Bruce from Mission Amps recommended a certain value in the reverb circuit, and the amp here matches those values, both the resistor and the cap...i believe it was 2.2k ohms, and 25mfd/25 volts.
