Hi everyone, Just wanted to know if its ok to use a 9DC power adapter on a 9AC device (in this case a Digitech RP1000 AC power version)
As far as i can tell there is a internal bridge rectifier circuit for AC to DC and looking at the power supply schematic it looks like no AC power is needed to run any other part of the board.
Am i wrong to assume this?
Just got parts in and repaired my damaged RP1000 mainboard (not by me) and wanted to find a cause for failure.
ATM the unit was supplied with a 9.5v DC power adapter putting out 9.85v DC. (AC adapter is DC regulated using a LM317 which I regulated now to 9v from 9.85v)
Im wanting to test it but before installing the audio processor I wanted to run the power supply's first to test all other repairs and power outputs.
Any advice or info will be helpful.
Thank you.
Thank you.
