I found a Futre light DMH-30 moving head at a Good Will store. Didn't work. They said take for parts. Looks like ADJ Visi LED spot.
No led output (flickers at times) but the motors run fine. Unit scans normally, just cant get the LED to stay on. I went through the reset procedures. This unit is very much like ADJ in function, layout and design. No errors reported on the display.
LED has V+, and it looks as if the V- is pwm controlled. Led tested ok with applied voltage independently, so this is definite a control issue. PS is there.
Never worked on one like this. Did some older lamp versions though. This has less in it that those.
Schematic
http://download.showtechnic.de/data/...s/00056234.pdf
Schematic
