Hoping someone has seen this before. I am working on a Fender Bassman Blackface. It appears to be an AC568 circuit. It has Bass and Normal channels each with Volume, Treble, and Bass controls. The Bass channel has a Deep switch and the Normal channel has a bright switch.
The issue occurs on both channels. As you turn the volume control down the volume decreases, but as soon as you turn it all the way down, rather than going silent, the signal comes back as if it were turned to 2 or 3.
I tried replacing the volume pot on one of the channels, but it still does it. One of the preamp tubes tested bad so I replaced it, but the problem still exists. It's got new filter caps. I'm ordering some of the other caps because they measure out of spec on my capacitance meter. Could they be the cause of my problem?
Thanks in advance!
Thanks in advance!
