I'm relearning basics, and I'm looking for a good general electronics forum for asking noobish questions. Any suggestions?
Good general electronics forum?
I think the "Music Ectronics" one that you posted your question in is a good one... I'm sure I can speak for many noobs (myself included) when I say we'd all like to benefit from your questions, and we probably have the samexquestions but are too embarrassed to ask. And even the humbler honest pros here will fess up to not knowing everything. Remember - "the only stupid question is the unasked one."
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Ok, instead of creating a new thread, here is a noob question: I relearned basic dc series, parallel, series/parallel theory the other day, just playing around with some resistors, doing the calculations, and measuring for comparison. For simplicity sake: for a single resistor that is measuring 545 ohm, across a power supply that is measuring 10.7 Vdc loaded, I'm measuring a current of around 3 mA, where I calculate 19.6 mA. What might be causing the difference, here?
Two semesters of electronics classes, and we never did this stuff... For anyone considering taking classes, check out your school thoroughly before signing up. Had I done a little prying, I could have found out that every single student in the program preceding mine failed their certification exams, that the school's overall graduation rate is lower than 20% (only really graduating business and nursing students), and that the school was having a very hard time finding competent instructors for the electronics tech classes. Believe me, it became obvious that there were major problems after just a few days in classes. I should have dropped right then, spending the money on books and tools instead. /End whatever this is.
Originally posted by mushy View Postfor a single resistor that is measuring 545 ohm, across a power supply that is measuring 10.7 Vdc loaded, I'm measuring a current of around 3 mA, where I calculate 19.6 mA. What might be causing the difference, here?
The meter is in series with the resistor and the probes are in the right jacks for current measurement? Do you have a second meter so you can check voltage across the resistor at the same time you are measuring current?
Also, some meters have fuses for the current ranges.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostSomething is not measuring the current right? I'll assume you have measured the resistor and it is 545 ohms.
Back to it. I'm sure I will have plenty more noob stuff to post in here.
Originally posted by mushy View PostI borrowed another meter, and all is right. Yep, mine is junk...harbor freight (it has also been loaned to everyone and his sister). It's not the fuse.
Read all this stuff!
NEETS - Navy Electricity and Electronics Training Series
PS 187 years and Georg Ohm is still on top!Last edited by tedmich; 05-19-2014, 01:54 AM.
Originally posted by tedmich View Posteverybody deals with measurement errors, theoretical stuff is all perfect!
Originally posted by mushy View PostAnother one: How can ac and dc exist on the same circuit without changing one another?
First a disclaimer: the AC in a guitar amp (for example) can be amplified and sent to the output terminals BECAUSE of the DC, so the assertion that the AC and DC don't change another might be a bit misleading.
In terms of measurement instruments, some are designed to sense whether there's more AC than DC present (or vice versa) and display a reading based on the stronger of the two elements. Other meters require the user to pick. Some may be better at rejecting DC when measuring AC than others, some may be better at averaging AC when measuring DC. A less-than-professional grade meter may be poor at differentiating the two sources and display garbage when both are present.
The distinction between AC and DC for the engineer or technician is an arbitrary one. DC is nothing more than an extremely low frequency AC wave component (zero Hertz, actually!) and can be treated that way mathematically. DC on your AC signal can be called an 'offset', and is common in an amp (remember the disclaimer). Between gain stages it is removed by using AC coupling capacitors. The DC component can be ignored for much amp circuit analysis, but is very important to keep in mind for calculating headroom, power, etc. We talk about the AC and DC like they're two different things, because their origins are usually different (in an amp, at least). But the AC wave gets more powerful from input to speakers as it takes energy provided by the DC.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostOK, I'm learning too, but I'll take a stab at it.
Thanks for the reply, btw. I think it is good to understand these types of things, and I never could get straight answers from instructors on these types of questions. One guy told me that he's a mechanical engineer, so don't ask him.Last edited by mushy; 05-19-2014, 03:17 AM.
There was an MXR multiFX unit back in the 70s', that "floated" control signals on the 12V DC supply to the pedal, and connected pedal to amp with any quarter-inch cable, nothing special needed. Another type of case of AC superimposed on DC.This isn't the future I signed up for.
Originally posted by mushy View PostSo dc creates an offset, moving the ac reference, from say 0V, to whatever the dc voltage is? I.e., the ac waveform is riding the dc line?
And a coupling cap moves the ac waveform back to a 0 reference.
One guy told me that he's a mechanical engineer, so don't ask him.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostIn an amp, how about the signal riding the bias voltage on its way to the output tube grids.
