Anybody know of an equivalent, preferably easy obtainable, for this transistor. It is a 50V 1,5A device. To-220. Pin ECB.
2SC2028 Equivalent
Audio lab of Ga
Edit: Sorry, just realized you are in South Africa. That link is probably not of much use to you. I'm leaving it up anyway in case anyone else is ever looking."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
In my entire life, I do not recall a TO220 transistor that was not pinned B-C-E.
I hate to see anyone using NTE, just my personal bias.
What would be wrong with a plain old TIP31C?
Transistors are not usually critical. If this is a voltage regulator circuit, just about anything will work. If it is a driver, look at other similar circuits and use what they use. If it drives a relay, then use anything.Education is what you're left with after you have forgotten what you have learned.
It appears that it is a TO126 case.
And the pinout is indeed ECB.
Here is a seller on EBay that has them: Universal Electronic Part Transistor New Never Installed 2SC 2028 | eBay
