Wurlitzer Spectratone - Solenoid?
  • Wurlitzer Spectratone - Solenoid?
    I recently picked up a Wurlitzer Spectratone unit - just the rotating speaker part. For those unfamiliar, this looks like a centrifuge to train mice for the space program. A pair of 4" speakers with a counterweight, spun by a motor. Probably the silliest way to get a Leslie sound, but it's fun and I got it for a song.
    There are a couple models of these, but this picture matches the one I have: File:Wurlitzer Model 4100 BW Rotating spectra tone speaker.jpg - Wikimedia Commons
    I need to replace the speakers (the seller was kind enough to provide a pair of 4" alnico drivers) and put an isolation transformer and fuse (and switch!) between the motor and the power cord. I also don't have the model with the relay to switch between high and low speed, or it was possibly removed.
    The part that really confuses me though is the plunger (solenoid?) attached to the wheel. Does anyone have an idea of what this is supposed to do?
    I think this is the correct schematic for the original organ/amp: http://i190.photobucket.com/albums/z...b200810002.jpg
    Thanks!
    Wouldn't the solenoid be used as a brake when activated?
    Just s thought.
      Yeah, that's what I'm wondering.
      Hah! There are more schematics here! Could've sworn I searched here first: http://music-electronics-forum.com/t25817/
      This schematic shows the solenoid between the 12" speakers and ground. So... something of a tremolo effect?
        This certainly appears to be related: Patent US3069958 - Vibrato apparatus - Google Patents
        So yes, the solenoid generates tremolo which is then fed to the stationary speaker(s) and optionally the rotating ones as well.
        The rotating speakers definitely need a high-pass filter; I'm guessing the premature distortion is being caused more by the rotary transformer saturating than the speakers themselves breaking up. Or it's at least a part of it.
        Now I get to make a box, a power supply, possibly a relay so I can switch the motor on and off with a footswitch...
        Man, I am just tickled pink by this thing.
          I have speakers for it if you still need it. I think I have 4 of them (32ohm each). They are original for that unit.
            32 ohm? Weird. Guess I gotta check the impedance ratio of the rotary transformer. They're wired in series so I guess it's probably about 8:1.
            Probably going to take me a while to get back to you as my fun funds are right around 0 for the time being. :/
              Sorry, just checked, they are 48 ohm...but they did come out of a spectratone.
