I just blew my dummy load's one side, the 8ohm side. It consists of some ARCOL 2ohm 50 Watt resistors in series.
I mounted the on a HUGE heatsink and a fan.
This time around one of my techies forgot to turn on the fan while he was testing. The culprit was a Behringer iNuke 6000 driven to almost clipping. Hell knows why this happened. Still pissed.
Anyways, I took it apart. The heatsink is fairly huge with some thin machine cut grooves cut into it, running across the length of the heatsink.
Maybe these 4 or so grooves running under each resistors is weakening the thermal contact of the res/heatsink. I did use thermal paste under them.
Would this play a big role, or was I just unlucky??
It there a way to fill these little grooves, or what can I use to cover them before installing resistors again.
I have plenty of Brass shim stock of varying thicknesses lying around. Would it work.
Any ideas welcome.
Any ideas welcome.
