Behringer UB mixers SPSU2 power supply noise
  • Behringer UB mixers SPSU2 power supply noise
    Hi I have a UB1832FX mixer for repair
    On one of the XLR outs, the one closest to the SMPS, there is a high freq noise. If i move my finger along the wire that connects smps to main board, the sound changes.
    I have checked ESR of all caps. All voltages read fine with little/no ripple. I have tried a ferrite bead on the connector cable with no luck.
    I have checked all secondary diodes.
    Any ideas?
    Nevermind. Found the culprit
      And the culprit was.....?
        Yes, please feel free to share information here as freely as others share it with you .
          I thought it was the power supply. Turns out it was an opamp after the right channel main fader, that was noisy and had bad psrr for some reason. IC39.
