My multimeter does not have AC measurement, but I need to find out how much AC current at 220VAC a 220VDC motor consumes?
I just connected the 220VDC motor onto the 220VAC we have in Chile via a rectifier bridge and a 2.5uF/400V electrolytic, but how to find out how much AC current the motor consumes?
I then did another test, by connecting the same motor via a small inverter with 12VDC input and 220VAC/75W output and it measured 1.3A/16W (at 12.3VDC inverter input).
There must be a way of calculating the approx.220VAC currant consumption from this data or is it not possible?
If not, I just have to buy a cheap AC clamp meter.
Thank you in advance for the help on that...
