Greetings! I wanted to ask how practical it is to use a cathode follower tube circuit as a simple mono out on a tube preamp as opposed to an output transformer.
Any Thoughts?
It depends what you want to drive and what tube you'd be using for the output. It's practical, but you need to have a definite load in mind. The current available with regular preamp tubes is fairly small and can still only drive a relatively high-impedance load (compared, say to an 8 ohm speaker). You can run two cathode followers in P-P in a Fletcher-Cooke configuration to improve drive capability, but it's still fairly limited output.
Any more current and you need to use power tubes to get a decent output. There have been quite a few designs published for OTL (output Transformerless) designs but they often use now hard to get tubes.
Why wouldn't you pick the signal straight off the plate if its just a preamp?
