LastNote
Amp had a loose filter cap, replaced all 22uf cap (not 47uf it was good and no leaks).
Put the amp together clean channel not working, dirty channel is good. LED indicator light is off when selector button is up and yellow when push in no red indicator light. Master vol working when selector button is push in position, vol does not work in any selector position. Tested all resistor on the small tube ckt board: R38,39,40, 41,42,43, 44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62 ,64,65,66,67,68,69,80,81 all test good. 5 Watt resistor R78 & 79 good at both end 48v in 16 v out. Voltage out of CR13 & 14 good at 16v—Any ideas
